Use this category:
Solved Installation failed with following error:
9 years 9 months ago #183350 by NeilT
I cleared the cache again, and for some strange reason the upgrade has now worked :)
That is a big relief.
I want to say a huge thank you to the Kunena team for the help/support and continued development.
Thank you.
9 years 9 months ago #183356 by pavel v ru
Do you have another method?
I have this advice did not help on an empty Joomla.
In the first case, the installation has failed.
After removing that already installed, the installation was successful, but the transition to a component, I got an error HTTP ERROR 500
If necessary, I can provide access to the admin panel.
9 years 9 months ago #183357 by 810
did you cleaned also joomla backend cache?
else try to install the package by the joomla installer, maybe try a different browser. Or try to update php
9 years 9 months ago #183358 by pavel v ru
my php is 5.4.45-0+deb7u6
php version complies with the requirements.
I cleaned the entire cache.
I tried a different browser (FireFox).
i have HTTP ERROR 500 again.
9 years 9 months ago #183360 by pavel v ru
on php 7.0 - works.
Strangely enough, my php meets the requirements.
9 years 9 months ago #183362 by 810
maybe a bug on php or joomla cache.
