Please note: The Kunena project team takes NO responsibility for maintaining nor supporting anything in this category.
Question Kunena Topic to Article component
9 months 3 days ago #234583 by lemur
Release 2.0.1 published  2.0.1  - 2026-02-071. The topic author is assigned as the article author
  • Fixed a coincidental error; now the author of the article is again assigned as the topic starter, not the administrator.
2. Plugin plg_system_kunenatopic2articleimgfix - Release v1.1.0
  • Improved Anchor Scrolling for Chromium/Gecko
🚀 What's New
  • This update addresses the common issue where browsers (especially Google Chrome and Microsoft Edge) fail to scroll to the specific post anchor (e.g., #2993) upon page load.
🛠 Fixes & Improvements
  • Disabled Native Scroll Restoration: Switched to history.scrollRestoration = 'manual' to prevent Chromium from interfering with the script-driven positioning.
  • Inline JavaScript Implementation: The fix is now injected directly into the page header, eliminating the need for external JS files and avoiding cache-related issues.
  • Post-Load Re-positioning: Added a retry mechanism that monitors page layout shifts for 1.2 seconds after the window.load event. This ensures that even if heavy images or ads load slowly, the browser will snap back to the correct post.
  • Vanilla JS: Removed jQuery dependency for this specific task to ensure the fastest possible execution.
📦 Installation
  • Download the plg_system_kunenatopic2articleimgfix.zip file.
  • Go to your Joomla Admin Panel: System -> Install -> Extensions.
  • Upload and install the package.
  • IMPORTANT: If you are installing this plugin for the first time, don't forget to Enable it. Go to System -> Plugins, find "System - Kunenatopic2articleimgfix", and click the status icon to make it active.
Signature:
Many thanks to Rich and the other advisors.
9 months 3 days ago - 9 months 3 days ago #234584 by lemur
Release 2.0.2 published
2.0.2  - 2026-02-191. Resolved a conflict between the component and the "Latest Articles" module
  • Fixed a conflict between the component and the "Latest Articles" module that could occur during article previews. As a result, users must now be logged into the site's frontend (in addition to the administrator panel) to view previews. If not logged in, the Preview button will trigger a helpful tooltip instead of opening the preview.
  • Relevant information has been added to the documentation.
Signature:
Last edit: 9 months 3 days ago by lemur.
8 months 4 days ago #234825 by lemur
The component and plugin have been tested for compatibility with Joomla 6 and Kunena 7.0.2.
​​​​​​​They work properly.A corresponding note has been added to the JED.
Signature:
4 months 6 days ago #235104 by lemur
A new Version 3.0.0 of the Kunena Topic to Article component on Github and JED has been published.
What’s New
Version 3.0.0
Changed:
- Major internal refactoring while preserving the existing article-generation workflow.
- Extracted Kunena reads, article rendering, traversal, notifications and result handling into dedicated classes.
- Updated compatibility work for Joomla 5/6 and Kunena 6/7.
- Post info block appearance can now be customized from the component form.
- Preview rendering now uses a frontend iframe.
Fixed:
- Improved handling of malformed BBCode fragments.
- Fixed external BBCode URL conversion cases.
- Fixed layout breakage caused by malformed video links.
- Fixed Link to Kunena Post output when post relation display is disabled.
Optional plugin:
- Updated the optional post-anchor positioning plugin to version 3.0.0.
- The plugin may partially improve Kunena's positioning on post anchors in long topics with many images.
Signature:
The following user(s) said Thank You: megat
4 months 4 days ago #235106 by megat
Sir, Thank you for your hard work, providing more modern solution for this great component, keep em coming! :)
The following user(s) said Thank You: lemur
2 months 3 weeks ago #235200 by lemur
Dear megat,
thank you so much for your kind words.
I would be very grateful if you would write your opinion in a short review on the Joomla Extensions Directory (JED) .
Thank you in advance.
Leon
PS Unfortunately, there is no private messaging service on this site, so I had to contact you directly in the subject.
Signature:
