Solved How to modify breadcrumbs display
1 year 6 months ago #233348 by sheepstations
Thanks for the code. Unfortunately it didn't work. I'll look into it further.
A big thanks about creating the Kunena menu. It wouldn't initiate on installation but I finally got it to work.
Thanks for your help.
JR
1 year 6 months ago #233349 by Pinkeltje
That is the wrong code as it should be somewhere in your custom.css or in your template. But if you disable css compression I will be able to see more.
1 year 6 months ago #233356 by sheepstations
Hello again, I have this code in the template custom.css file.
.breadcrumb .breadcrumb-item + .breadcrumb-item
{ padding-left: 0;
I also turned off CSS optimisation in the template global settings.
Is that correct?
1 year 6 months ago #233357 by rich
He only drew your attention to the fact that you have this definition in one of your CSS files. padding 0 means no spacing.
To achieve what you want, you have to enter the spacing value.
This should work here:
.breadcrumb .breadcrumb-item + .breadcrumb-item {     padding-left: 0.5em; }
The following user(s) said Thank You: sheepstations
1 year 6 months ago #233358 by sheepstations
Thank you, that worked!
Unfortunately I know enough to be dangerous when it comes to css but not enough to come up with a fix like that.
Thanks for helping.
JR
1 year 6 months ago #233359 by Pinkeltje
@rich "he" is a "she"
It has something to do with the template or with custom overrides as the template.css also has this 0 value (difficult to see now as css compression is on again).
So indeed overriding it like you suggested is for now the only solution, That still doesn't explain why the dividers (:before) are missing. So @sheepstations I suggest you contact Joomlart about this as this is a commercial template.
