Solved How to modify breadcrumbs display
- sheepstations
When I display a post, all the breadcrumbs run into each other (no spacing between words) which is quite confusing.
For example: ForumDiscussionsOceanFarmingDiscussionForumTheBrunyIslandProject
I'd like it to display: Forum Discussions Ocean Farming Discussion Forum The Bruny Island Project
(or in a perfect world Forum | Discussions | Ocean Farming Discussion Forum | The Bruny Island Project
Can any body tell me how/where to modify the breadcrumb display?
Thanks,
JR
- Thank you received: 194
- sheepstations
I've tried yes and no options for the "Load Bootstrap css" option.
It makes no difference.
Any other suggestions? Possibly may have to coded into an appropriate file??
JR
- sheepstations
channelseafarms.com.au/forum/discussions...ity-for-bruny-island
BTW: You don't have a Kunena menu, so fix that as well.
www.kunena.org/docs/en/troubleshooting/menu-issues
