Solved Change entry in aurelia/BBCode
2 years 4 months ago #231712 by Pinkeltje
@rich: I've added a bug report with solution.
The following user(s) said Thank You: rich, Gindi
2 years 4 months ago #231714 by rich
Replied by rich on topic Change entry in aurelia/BBCode
@Pinkeltje
Thank you very much!
Note: I edited your post at git because the link to this topic didn't work.
The following user(s) said Thank You: Pinkeltje, Gindi
2 years 4 months ago #231719 by Gindi
@pinkeltje, your solution is ingenious and works perfectly.
The function description has not been displayed since Kunena 3.
Since the BlueEagle5 template, the lines in edit.php exist without your addition. There the function description was displayed when you moved the mouse over the function on the left.
gindi
