Solved Change entry in aurelia/BBCode
2 years 4 months ago - 2 years 4 months ago #231677 by Gindi
I have tried to change the entry "X symbol in the editor" in the aurelia/BBCode template on my test server.In the file /administrator/language/en-DE/en-DE.com_kunena.views.ini I have the lines COM_KUNENA_TEMPLATE_DISPLAY_X_SOCIAL = "<strong>X</strong> symbol in the editor" and
COM_KUNENA_TEMPLATE_DISPLAY_X_SOCIAL_DESC = "Show symbol for <strong>X</strong> in the editor" in COM_KUNENA_TEMPLATE_DISPLAY_X_SOCIAL = "<strong>X_Social</strong> symbol in the editor" and
COM_KUNENA_TEMPLATE_DISPLAY_X_SOCIAL_DESC = "Show symbol for <strong>X_Social</strong> in the editor" renamed.
Unfortunately, the entry "X symbol in the editor" has not changed.To make sure that nothing else has an influence, I created a new test server version and installed there only the bare Joomla 5.1.1 and Kunena 6.3.2 in the pure version.There I have also made the changes to the language file without changing anything.I also find it strange that I can't find the entries "Instagram icon in editor" and "Soundcloud icon in editor" in this language file although they are in aurelia/BBCode with "Ebay icon in editor" and "X icon in editor".
I also cannot find another file in which I could change the entry.
Does anyone have a tip for me?
gindi
Last edit: 2 years 4 months ago by Gindi.
2 years 4 months ago - 2 years 4 months ago #231681 by Pinkeltje
Where is
en-DE
coming from?
Have you tried using language overrides?
Last edit: 2 years 4 months ago by Pinkeltje.
2 years 4 months ago #231683 by Gindi
Sorry, that's a careless mistake. Of course, /administrator/language/de-DE/de-DE.com_kunena.views.ini is correct.
gindi
2 years 4 months ago #231685 by Pinkeltje
I don't know where entries with _DESC are used (normally the appear when using show inline help button, but Kunena doesn't have this), but making an override (which is safer because it can't be overwritten by updates) should work for this one.
2 years 4 months ago - 2 years 4 months ago #231689 by rich
Replied by rich on topic Change entry in aurelia/BBCode
I hadn't realised that the "_DESC" displays had disappeared.
It used to look like this:
But we have unnecessary language lines in the frontend because the same strings are also present in the admin views.ini and are only used in the backend.
@Gindi, I have a tip for you. As far as I know, you have Linux as your operating system. You can use the grep search tool.
Example:
1. download Kunena from git and unpack this zip
2. navigate with ~$ cd /path to the folder Kunena-Forum-K6.3/
3. enter grep -R -i -n --include=*.ini "COM_KUNENA_TEMPLATE_DISPLAY_X_SOCIAL"
This would have shown you all results including line numbers in the ini files within one second.
Last edit: 2 years 4 months ago by rich.
2 years 4 months ago #231707 by Gindi
@rich, thanks for the tip.
I have now successfully managed to change the entry "X symbol in editor" to "X_Social symbol in editor" in aurelia/BBCode on my test server.
I had to change the file /languages/de-DE/de-DE.com_kunena.templates.ini.
The problem is solved.
gindi
