Solved Kunena does not shows threads, posts, messages & the login table!
3 years 6 months ago - 3 years 6 months ago #227507 by rich
  1. If your provider no longer provides the outdated PHP 5.3.x or PHP 5.4.x, you need a local server installation with one of these PHP versions and a clone of your website.
  2. Then you have to install Kunena 4.0.12 as an intermediate step (only then you can migrate to Kunena 5.0.x .)
  3. When this is done and everything works, you need a server with at least PHP 7.4.1.
  4. On this server you need a clone of your website with the Kunena 5.0.x installation.
  5. Upgrade Joomla to 3.10 and Kunena to 5.2.
  6. Then check everything again.
Important: Make a complete backup after each step and an extra backup of all Kunena tables to be able to access them at any time.
How to upgrade to Joomla 4.2 and Kunena 6.0 is described here: docs.kunena.org/en/basics/upgrade/upgrade-k6-0
Sorry if it's so much, but the longer you wait to upgrade/migrate, the more difficult it is.
Last edit: 3 years 6 months ago by rich.
The following user(s) said Thank You: sentiogr
3 years 6 months ago #227535 by sentiogr
I followed your instructions and everything went well! Thanks a lot for your response! :)
Time to create page: 0.207 seconds
