Solved Thumbnails File Info in Posts
3 years 9 months ago - 3 years 9 months ago #227148 by PhilF51`
Hi Rich,
I have entered the code in the template custom scss.  I have left it as is so you can look at the error.
Last edit: 3 years 9 months ago by PhilF51`.
3 years 9 months ago #227149 by rich
Replied by rich on topic Thumbnails File Info in Posts
I can't find the custom.scss on your page, but the error message is: "custom.scss in line 8". Why do you have 8 lines in your custom.scss? My code only has 6 lines. Can you please post here what you have entered in the custom.scss?
3 years 9 months ago #227151 by PhilF51`
This is copied from the custom scss.
.btn.btn-outline-primary.border.btn-sm {
display:none;
.col-md-3.text-center {
max-width: 9rem;
3 years 9 months ago - 3 years 9 months ago #227152 by rich
Have you entered also the dots at begin ans at the end? If yes, these must be removed. Enter only this:
.btn.btn-outline-primary.border.btn-sm { display:none; } .col-md-3.text-center { max-width: 9rem; }
Last edit: 3 years 9 months ago by rich.
3 years 9 months ago #227153 by rich
I have just seen that it works now.
3 years 9 months ago #227156 by PhilF51`
Oops!  Not too familiar with coding so not totally sure what was needed.  However, many thanks Rich.  It now works.    The file name appears only on hover now
Cheers.
