Solved Thumbnails File Info in Posts
3 years 9 months ago #227126 by PhilF51`
Joomla 4.04, latest stable version of Kunena 6.  Thumbnails are set at 100px, file name switched off. However, the file icon alongside is quite large and rather intrusive.  It was acceptable when I was using Joomla 3 and Kunena 5.  I appreciate the template has some influence over the styling. Is there a way of removing this file icon as I feel it is unnecessary as my users are more interested in the image than the file name?
  • rich
  • rich's Avatar
  • Online
  • Kunena Moderator
  • Kunena Moderator
  • I like sunshine and flowers
3 years 9 months ago #227130 by rich
Replied by rich on topic Thumbnails File Info in Posts
You can hide it via CSS. But if I can't see the forum, I can only guess.
Try the following code in your custom.sccs ( same way as here ).
.btn.btn-outline-primary.border.btn-sm {   display: none; } .col-md-3.text-center {   max-width: 50px; }
3 years 9 months ago - 3 years 9 months ago #227143 by PhilF51`
Hi Rich,  I think I placed the code in the correct directory as per your link. I got a "Gantry error" immediately.  As per the issue here is the link to my work in progress site and an example post  dev2.wimbornemac.org/forum/kits-and-scra.../2434-stearman-build
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 256M | Max file upload:
Joomla default template details : rt_notio | author: RocketTheme, LLC | version: 1.5.0 | creationdate: October 29, 2021
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.7 | creationdate: 2022-12-14
Kunena template params:
Kunena version detailed: Kunena 6.0.7 | 2022-12-14 [ Git Repository ]
Plugins: None
Modules: Kunena Latest 6.0.2
Last edit: 3 years 9 months ago by PhilF51`.
  • rich
  • rich's Avatar
  • Online
  • Kunena Moderator
  • Kunena Moderator
3 years 9 months ago - 3 years 9 months ago #227145 by rich
Try this, it should work.
.btn.btn-outline-primary.border.btn-sm {   display: none; } .col-md-3.text-center {   max-width: 9em; }
Last edit: 3 years 9 months ago by rich.
3 years 9 months ago #227146 by PhilF51`
That is exactly what I wish Rich.   However, I got "  0 parse error: failed at `.` D:\Xammp\htdocs\components\com_kunena\template\aurelia\assets\scss\custom.scss on line 10, at column 1".
My method. Template Aurelia.  Edit SCSS.  Click Custom SCSS. Paste text.  Save.   Obviously I am doing something wrong.
  • rich
  • rich's Avatar
  • Online
  • Kunena Moderator
  • Kunena Moderator
3 years 9 months ago #227147 by rich
Please enter this code again, I will check it.
Time to create page: 0.188 seconds
