Solved Help for newbie. Just installed Kunena
- OldCharlie
- Senior Member
- OldCharlie
- Senior Member
See 7thHeaven.cloud
- Thank you received: 2545
- OldCharlie
- Senior Member
Here is what I have done, yet I still cannot make it possible for anyone to contribute to this forum. Can you contribute? Go to Lindy Alert
2. You've chosen Review
Review means, an Admin or global moderator must check the user post, and afterwards approve.
You see on my image the correct setting.
Green hook means yes
Red symbol means no
Therefore, you need the red symbol at these options (see image).
- OldCharlie
- Senior Member
