- Thank you received: 2545
Solved Enlarge icons under button 'More'
As I've written in my first reply, the gender symbols is an image. So you need first the gender symbols image with the correct size. Both symbols (man and women) must be on this image. Afterwards it needs again a css correction, because this image must be adjusted as background image on the right place.The female/male could be a bit larger.
Is there any reason why you have set "Load bootstrap css" in the Crypsis setting? With your Joomla default template Protostar it should work without this setting. If you have no problem without this setting disable it and the symbol will display with correct contours.The original aim was to enlarge so that people would recognize an envelope. I see on your result a sharp lining on the envelope whereas mine is still unclear.
- HanKortekaas
- Premium Member
- familiewapen
I think I leave it like that. Thanks
(answering this I get the same delay in response time as my topic on my website)
Han
The complete path is: /components/com_kunena/template/crypsis/assets/iconsets/profile/default/gender.png
Replace the old codes with these codes. Add all this codes in your custom.less docs.kunena.org/en/manual/backend/templates/edit-less
