Solved Enlarge icons under button 'More'
6 years 5 months ago #213227 by HanKortekaas
I have looked in the documentation but can not find how to enlarge all icons under the 'More' button. I do not find the names of the icons under the LESS catagory. Mainly the e-mail envelope looks like a black box.
Han
6 years 5 months ago #213235 by rich
The gender symbol is a image and the other symbols are fonts. Try this code in your custom.less docs.kunena.org/en/manual/backend/templates/edit-less
.profile-expand.center i { font-size: large; } .kicon-profile-gender-female, .kicon-profile-gender-male { margin-bottom: 5px; }
Afterwards empty all caches (Joomla and Browser).
6 years 5 months ago #213254 by HanKortekaas
Rich,
that doesn't work.
Han
6 years 5 months ago #213271 by rich
If you use the Joomla default template Protostar and Crypsis with bootstrap 2 symbols it should work.
6 years 5 months ago #213274 by HanKortekaas
It does not
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.16 | creationdate: 2020-03-17
Kunena template params:
Kunena version detailed: Kunena 5.1.16 | 2020-03-17 [ Pallene ]
Plugins: None
Han
6 years 5 months ago #213279 by rich
Such small symbols are often persistent in the cache. Refresh your page a few times with Ctrl + F5
You can also try with "!important" at the end of this code.
.profile-expand.center i { font-size: large !important; } .kicon-profile-gender-female, .kicon-profile-gender-male { margin-bottom: 5px !important; }
If that doesn't help, I'd have to see it.
Time to create page: 0.160 seconds
