Solved Rendering Error after login
I don't understand what you mean by that.rich wrote: Whereby the mistakes had one thing in common, mostly the template has compiled a wrong address to any file.
Is there a file/directory somewhere, where I need to take look and clean up?
- Thank you received: 2545
I think, a example is your error message:I don't understand what you mean by that.
Rendering Error in layout Widget/Module: Call to a member function cachedCompile() on null in /var/www/vhosts/transalpclub.nl/kunena.transalpclub.nl/plugins/system/helix3/core/helix3.php on line 774
Layout was rendered in /var/www/vhosts/transalpclub.nl/kunena.transalpclub.nl/components/com_kunena/template/crypsisb3/layouts/page/default.php on line 25
That's a wrong address. Add only the red marked address (with www. at the beginning) in your browser address field and press Enter. Then you will see it. I think, the author of your Helix template could better help.
What you marked in red is part of the directory structure in the backend. I'm not entirely sure if the transalpclub.nl is in the path. But I will ask the guy who provides the hosting.
Anyhow, if I paste kunena.transalpclub.nl/components/com_kunena/template/crypsisb3/layouts/page/default.php in my browser, I get a blank page. No errors. For kunena.transalpclub.nl/plugins/system/helix3/core/helix3.php I get a page saying resticted aceess.
I will ask the makers of the template as well. I believe, they in turn have full access to the support forum of the Helix3 developers, JoomShaper. I'll report back.
The issue is definitely in the code of the template. So, you can close this topic.
