Solved Attachment message: Audio clip: Adobe Flash Player
7 years 9 months ago #207623 by meteo
Hi rich
I searched the positions....but I don't fount them.
Totally confused is: I have NO position with the beginning-string: kunena_ .....
Oh oh ...... how can this be?
Should I give you the adminlogin by PN or mail?
Markus
Joomla: 3.9.2
Kunena: 5.0.12
swisswetterforum.ch
7 years 9 months ago - 7 years 9 months ago #207691 by rich
I've found the cause. It's your installed audio player rapid pixelout. The 1pixeloutKunena.min.js of this audio player contains in the code ("kmsgattach","div");
But the class="kmsgattach" is the container for the the Kunena attachment symbols.
I don't know this audio player, but check the setting. Maybe this place was chosen for displaying media files?
Last edit: 7 years 9 months ago by rich.
The following user(s) said Thank You: meteo
7 years 9 months ago #207696 by meteo
Dear rich
Wooooow, this was the Solution !
I have deactivated the Plugin..... and the message is blown away :-)
Thanks a lot!
Best regards
Markus
Joomla: 3.9.2
Kunena: 5.0.12
swisswetterforum.ch
