Solved Attachment message: Audio clip: Adobe Flash Player
7 years 9 months ago #207565 by meteo
Hi
If someone post something with attachments, ther ist the following message:
Audio clip: Adobe Flash Player (version 9 or above) is required to play this audio clip. Download the latest version <a href=" www.adobe.com/shockwave/download/downloa...veFlash&promoid=BIOW " title="Download Adobe Flash Player">here</a>. You also need to have JavaScript enabled in your browser.
Why is there this message: Flash ist completely old trash!
Thanks for a hint,
Markus
Joomla: 3.9.2
Kunena: 5.0.12
swisswetterforum.ch
7 years 9 months ago - 7 years 9 months ago #207575 by Bigbunny
This is a problem in that nobody should be using Shockwave or Flash these day. Unfortunately many up-loaders don't realise that and also don't know how to convert. There are some big companies that still have Flash videos on their sites and I have contacted some myself but most just ignore that. So you have a secure browser and they want you to compromise that with Shockwave and Flash. (Downloads are slightly different.)
A better solution would be not to just tell people that try to view the video that they need to download Flash but to say that Flash has been deprecated and compromises the security of your browser. Personally any site that asks me to use Flash I don't use, even though I have ways of downloading the flash content and know how to convert.
This is similar to several years ago Santander UK were telling everybody that used Firefox or Chrome, and probably other web browsers, to upgrade their web browser to IE. Anybody that knew anything about browser knew that both of these browsers were superior to IE and also followed W3 standards more closely. This also virtually assumed everybody was using Windows. This was following an EU anti trust ruling against Microsoft who were trying to force all of their user to use IE and keep other Browsers out. I pointed this out to Santander on several occasions, and though they acknowledged receipt of the communications they then ignored them. A few years later they changed their attitude, probably as they had to, Interestingly MS has virtually dropped dropped IE and is in the process of dropping Edge and are moving across to Chromium the same open source engine used in Chrome and some other browsers.
Last edit: 7 years 9 months ago by Bigbunny. Reason: Changed a word for grammar reasons.
7 years 9 months ago #207576 by meteo
Hi Bigbunny
Thanks for your reply.
The screenshot above is NOT a screenshot from a posting who has Flash or Shockwave-attachements !
This is a Posting I made this Morning with 3 .jpg Files as attachements.
So: Why make Kunena this absolutely wrong message?
Markus
Joomla: 3.9.2
Kunena: 5.0.12
swisswetterforum.ch
7 years 9 months ago #207580 by rich
This message will not created by Kunena, it comes from the browser. This is a module position and it seems, you have a flash advertising banner at this place.
7 years 9 months ago #207591 by meteo
Hi rich
You have absolutely right !!!!
See here:
www.swisswetterforum.ch/valium-praline/41471-hmmm?start=12
If you open this URL with Edge and then in "internetexplorer-Modus", you see this:
But - what the hell - where have I inserted this?
I have no idea.....
Markus
Joomla: 3.9.2
Kunena: 5.0.12
swisswetterforum.ch
7 years 9 months ago #207592 by rich
Go to "Extensions -> Modules" and search a module which is placed on the position kunena_msg_* or kunena_msg_row_*
Instead of * you see a number. You can disable this module or edit the content of this module.
The following user(s) said Thank You: meteo
