Solved Unable to set custom category images
10 years 3 months ago #178153 by Arlekino999
Followed instructions on www.kunena.org/docs/en/manual/backend/categories/category-icons but still blanks are displayed for custom images. Proper images were ftped and custom.css modified. Please, assist.
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 1024M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.11 | creationdate: 2016-06-05
Kunena version detailed: Kunena 4.0.11 | 2016-06-05 [ Barcelona ]
Third-party components: CommunityBuilder 2.0.14+build.2016.07.19.01.59.29.f1d8bdbed
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 3.1.2
Modules: Kunena Latest 3.1.2.1 | Kunena Login 3.1.2
10 years 3 months ago #178155 by rich
Please see here. Maybe your image is to big?
The following user(s) said Thank You: Arlekino999
10 years 3 months ago #178159 by Arlekino999
Image was resized prior to posting.
10 years 3 months ago #178161 by rich
It seems, that your cache is not empty. Check if the folder "cache/kunena" is empty.
10 years 3 months ago #178165 by Arlekino999
Cleared cache again and removed folder content per instructions. Did not help.
Attachment not found
10 years 3 months ago #178199 by rich
You do not have permissions to access this page.
Maybe are incorrectly configured rights?. Try again clear the cache. Then check the cache folder. If the Kunena folder still exists, you have a problem with the cache.
According to your posted images, you've made everything correct.
Check also the image in "media/kunena/category_icons" maybe it is broken during the upload.
Time to create page: 0.157 seconds
