Kunena 5.2.10.1 released (29 Sep 2022)
The Kunena team has announce the arrival of Kunena 5.2.10.1 [K 5.2.10.1] which is now available for download as a native Joomla extension for J! 3.10.x This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the development stages of K 5.2.9
Solved H1 Titles in Kunena!
6 years 3 months ago #31 by sozzled
Replied by sozzled on topic H1 Titles in Kunena!
romagromov wrote: This is a BUG in stable version.
I agree with you and so, too, do others who have contributed to this discussion. The developers, on the other hand, seem to have as different view about K 4.0 as indicated in msg #24 above. Apparently (unless I have misunderstood what was written in msg #24 above) there will be no bugfixes for K 4.0. But, we can wait to see if there's been a change of heart. As I understand the message, if you use K 4.0—the current stable version—you have to live with it as it is. Sorry.
6 years 3 months ago - 6 years 3 months ago #32 by romagromov
Replied by romagromov on topic H1 Titles in Kunena!
Ok, I trying to fix it.
But Kunena have very tangled code.
I found, that Blue Eagle template generates Meta Description and Keywords from this file:
/components/com_kunena/views/topic/view.html.php
Crypsis get Meta Description and Keywords from here
/components/com_kunena/controller/topic/item/display.php
Line 149
code
$this->headerText = JText::_('COM_KUNENA_TOPIC') . ' ' . html_entity_decode($this->topic->displayField('subject'));
UPD.
I got it!
I need some time to fix it.
Download Free Software for Windows absolutly free.
Last edit: 6 years 3 months ago by romagromov.
6 years 3 months ago - 6 years 3 months ago #33 by romagromov
Fix of Meta Description and Meta Keywords for Crypsis template
Open file /components/com_kunena/controller/topic/item/display.php
Found code in line 374
$this->setKeywords($headerText);
replace with
$this->setKeywords($this->topic->subject.', '.$this->category->name.', '.$this->category->getParent()->name.', '.$this->config->board_title);
Found code in line 384
$this->setDescription($description);
replace with
$description = KunenaHtmlParser::stripBBCode($this->topic->first_post_message, 182);
$description = preg_replace('/\s+/', ' ', $description); // remove newlines
$description = trim($description); // Remove trailing spaces and beginning
$page = $this->pagination->pagesCurrent;
$total = $this->pagination->pagesTotal;
$page = ($total > 1 ? " ({$page}/{$total})" : '');
$this->setDescription($description.$page);
File in attachment. File renamed in .txt - this forum do not able to upload php files.
Rename it with display.php
Meta tags will displays as in Blue Eagle template. Of course after update changes will be lost.
Also I fixed H1, H2 headers in Crypsis.
Now Topic, Category and Forum Title use H1.
Topics in Category use H2.
Also removed link from H1.
Attached too.
6 years 3 months ago #34 by 810
Replied by 810 on topic H1 Titles in Kunena!
@romagromov
you not allowed to use H1 H2 ect in tables.
Thats why it isn't easy to change the code.
6 years 3 months ago - 6 years 3 months ago #35 by romagromov
H1 is not inside tables.
Who forbids the use of H2 in tables?
Let us assume that this is so.
Why you use tables???
It's too old layout method.
Now we should use divs or ul lists.
Anyway, I fixed meta tags. Hope you'll add it in package.
6 years 3 months ago #36 by 810
when you will do a W3C Validation check, then you will be warned to change this code.
6 years 3 months ago - 6 years 3 months ago #37 by romagromov
Even if it were so, It much better to have H1 and H2 with wrong html markup, than not to have H1, H2 at all. ;)
I also want to notice, that wrong html markup does not affect on ranking.
I have checked category page, in which all topics have H2 in table.
No any warnings about that.
The following user(s) said Thank You: ChaosHead
6 years 3 months ago #38 by Josh
Replied by Josh on topic H1 Titles in Kunena!
810 wrote: For the H1, i will add a template option
I don't see this option in RC3. Perhaps I'm missing something?
6 years 3 months ago #39 by 810
still looking for the right solution.
its not correct to have H in the tables.
6 years 3 months ago - 6 years 3 months ago #40 by Josh
I agree. However I don't understand why it would be inside of a table in the first place. You can see that the H3 DOM element is not placed in a table:
Last edit: 6 years 3 months ago by Josh.
  • Not Allowed: to reply.
