Solved I get suscribed to every topic I answer
10 years 6 months ago - 10 years 4 months ago #175133 by findelat
Hello;
Since the last update to K 4 I got checked SUSCRIBE box... I think I have configured this as NO but every time I place an answer I got suscribed :S
This is my configuration report
Last edit: 10 years 4 months ago by findelat.
10 years 6 months ago #175136 by 810
login - go to your profile - edit - forum settings
there is a setting for subscription
The following user(s) said Thank You: findelat
10 years 6 months ago #175142 by findelat
First of all, thank you for your help. I didn't know this was enabled for everyone... I guess I should notice it to the users to let them know how to manage
10 years 6 months ago #175145 by 810
if you want to change the default setting for new users, you can change the setting on configuration.
