Question Problems with the upload button now working - jQuery is not defined
10 years 7 months ago #174366 by xillibit
HardstylerDK wrote: Yes i saw that.
But the weird thing is, that I've set almost everyone of the bbcodes to not show, but they show up anyways. :S
How do-you have disabled most of the bbcode icons ?
You should have these inline javascript code :
kunena_upload_files_rem = '/forum/topic/task-removeattachments?format=json&f23d98b283e1f51a478d236bf9d5eee5=1'; kunena_upload_files_preload = '/forum/topic/task-loadattachments?format=json&f23d98b283e1f51a478d236bf9d5eee5=1'; kunena_upload_files_maxfiles = '8'; kunena_showvideotag=1; kunena_disemoticons=1; kunena_showebaytag=0; kunena_showspoilertag=1; kunena_showmapstag=1; kunena_showtwittertag=1; kunena_showlinktag=1; kunena_showpicturetag=1; kunena_showhidetag=1; kunena_showtabletag=1; kunena_showcodetag=1; kunena_showquotetag=1; kunena_showdividertag=0;
10 years 7 months ago #174368 by HardstylerDK
Where will if find these inline javascript codes?
I've tried disabling them in both the template options, and the kunena component options, but non of them seems to remove these icons/functions.
10 years 7 months ago #174373 by xillibit
These lines are normally on the source code of the page when you write a new topic, but in our case it doesn't appear
10 years 7 months ago #174374 by HardstylerDK
Is it something that are generated by Kunena, or Joomla? Cause i haven't touched any files from the Kunena component, plugins or anything related to Kunena.
10 years 7 months ago #174375 by HardstylerDK
As you can see here, I've set everything to not show, but it still shows up, when creating a new topic.
10 years 7 months ago - 10 years 7 months ago #174390 by xillibit
HardstylerDK wrote: Is it something that are generated by Kunena, or Joomla? Cause i haven't touched any files from the Kunena component, plugins or anything related to Kunena.
This is something generated by Kunena
HardstylerDK wrote: As you can see here, I've set everything to not show, but it still shows up, when creating a new topic.
In this case i need to check in the Crypsis B3 template is the javascript part showed above is right generated
Do-you use Joomla! plugins to combine, minify javascript or which could remove this javascript code ?
Last edit: 10 years 7 months ago by xillibit.
Time to create page: 0.146 seconds
