Question Problems with the upload button now working - jQuery is not defined
10 years 7 months ago #174339 by HardstylerDK
Hi guys,
Just installed the newest version of Kunena on my site.
But i'm having some troubles with the upload button, which doesn't work at all.
In firebug i can see that there's some jQuery related problems, and i hope that someone in here could help me out.
htaccess: Exists | PHP environment: Max execution time: 1800 seconds | Max execution memory: 128M | Max file upload: 30M
Joomla default template details : sj_thedaily | author: YouTech Company | version: 1.0.1 | creationdate: 28/02/2015
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party SEF components: sh404sef 4.7.3.3292
Plugins: None
10 years 7 months ago #174340 by xillibit
I can't see exactly the errors messages displayed in error console, can-you please write them here ?
10 years 7 months ago #174341 by HardstylerDK
Wouldn't it be easier if i sent you some login details, so you can see it for yourself?
If so, how would it sent it to you?
10 years 7 months ago #174343 by xillibit
Yes, it will more easier, sent it to florian [@] kunena.org
10 years 7 months ago #174344 by HardstylerDK
A mail including the login information has just been sent to you. :)
Looking forward to see if you can fix these annoying problems. :)
10 years 7 months ago #174345 by xillibit
The file /media/system/js/core.js isn't loaded, so let it loaded and check if it works after
