Solved Problem with Cache or something else?
10 years 9 months ago - 10 years 9 months ago #173120 by milas
Everything i try i can’t make it to work or find where is error.
If I EDIT massage in post and I click APPLY… massage is closed but nothing happened in topic (it doesn’t show edited massage). Must click refresh than I can see edited massage and I can see announcement at top that Your massage is successfully edited.
Example
1. Edit massage
2. When I edit something and click Apply nothing show in edited massage
3. When I click refresh in browser than it shows edited massage and announcement massage in top
I try with different browser clear cache in browser and in joomla. Turn on/off system cache in joomla but nothing works. Try different template but no luck
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 150M
Joomla default template details : yoo_streamline | author: YOOtheme | version: 1.0.9 | creationdate: July 2012
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: UddeIM 3.7
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 3.1.2
Modules: Kunena Latest 3.1.2.1 | Kunena Login 3.1.2
Last edit: 10 years 9 months ago by milas.
10 years 9 months ago #173122 by 810
I think you have enabled plugin browser cache, disable it. And check again.
10 years 9 months ago #173123 by milas
I checked plug-in is disabled :(
10 years 9 months ago #173124 by 810
what are you settings on joomla configuration at cache?
10 years 9 months ago #173127 by milas
Like I said I try with on and off in Joomla configuration of cache but no difference. I put everything off in Joomla cache in Kunena and in template but no luck
10 years 9 months ago #173128 by 810
Can be also a hosting caching feature.
Time to create page: 0.152 seconds
