Solved Crypsis custom icons
10 years 10 months ago #172434 by 810
Replied by 810 on topic Crypsis custom icons
If you use less files,
You don't need the #Kunena class
10 years 10 months ago #172435 by antonio123
Replied by antonio123 on topic Crypsis custom icons
Ok went ahead and removed it, but the icon still wont show.
10 years 10 months ago #172436 by 810
on the image i see you paste the image on media/kunena/category_icons/icons
should be media/kunena/category_icons/
or you need to add icons dir on the less file.
10 years 10 months ago #172437 by antonio123
Great. Now how do I get it the same color as the other icons?
10 years 10 months ago #172438 by 810
If css icon
pick a color on the setting on edit template.
But if you use a image, then you should edit the image.
10 years 9 months ago #172651 by Fabien
Replied by Fabien on topic Crypsis custom icons
I have the same issue but i don't found how to solve it. I followed step by step what you said in this topic and in kunena's documentation but there is still no icon, can you help me ?
I have installed 4.0.9 version of kunena. When i select crypsis' template no icon appear.
I uploaded my image koala.png and i wrote this code on custom.less (i created it because no file exist)
see attachements
