Solved UTF-8 Character set issues
10 years 10 months ago #172403 by mlines
Replied by mlines on topic UTF-8 Character set issues
Ah, I do not have the default Joomla templates installed as we stripped the system to the bare minimum to ensure all possible hack points for the site were removed.
I only have js_onyx template and the Kunena templates on the site. js_onyx is written in the Wright framework so there is no obvious place for me to edit the index.php
Martin
10 years 10 months ago #172404 by mlines
However I note that if I view the source of www.bigjimny.com/forum that it has this in the first few lines.....
<!DOCTYPE html>
<html lang="en-GB" dir="ltr">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
<meta name="keywords" content="test, BigJimny Shop and Website, Suzuki Jimny, BigJimny Forum" />
10 years 10 months ago - 10 years 10 months ago #172405 by 810
Replied by 810 on topic UTF-8 Character set issues
please upload the joomla template. and try with that one, then you know its not your template.
It can be also a plugin thats causes the issue.
Last edit: 10 years 10 months ago by 810.
10 years 10 months ago #172406 by mlines
I have installed a standard joomla template and it still does the same (Beez)
10 years 10 months ago #172407 by 810
then disable sef, and rename the .htaccess then try again.
10 years 10 months ago #172409 by mlines
Neither SEF or removing .htaccess changed the issue
P.S - Many thanks for this help!
