Solved UTF-8 Character set issues
10 years 10 months ago - 10 years 10 months ago #172392 by mlines
My website was hacked before christmas and was cleaned up for me by a security consultancy who were excellent.
However, since then I have issues with the character set in Kunena. Being in the UK my members use the UK currency symbol - the £ symbol - frequently
Every instance of the pound symbol appears as £ which is some sort of utf-8 issue as far as I can see.
I cannot find where this issue is generated from.
PHP5 is set to UTF8
The database collation is utf8-general ci and UTF8
www.bigjimny.com/forum
Kunena is 4.0.9
Within the main Joomla website (blogs etc.) the £ symbol is correct, its just within Kunena.
Any ideas where to look as I have spent hours on this so far
Last edit: 10 years 10 months ago by mlines.
10 years 10 months ago #172396 by 810
Replied by 810 on topic UTF-8 Character set issues
please try this:
1) install admin tools
2) click on "Database Collation"
3) click on "Apply"
then check kunena again. (maybe its only working on new topics, you need to check that)
10 years 10 months ago #172398 by mlines
Replied by mlines on topic UTF-8 Character set issues
Thanks, I had already reset the collation.
I have just tried it again through Admin Tools and it has not cured it.
Martin
10 years 10 months ago #172400 by 810
ok, then look on the joomla sysinfo, that default_charset = utf-8
Please add kunena report:
backend - components - kunena - tools - report
10 years 10 months ago #172401 by mlines
I cannot find default charset in the System Info. The only entry is Database Collation utf8_general_ci
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : js_onyx | author: Casey Lee for Joomlashack | version: 2.0.2 | creationdate: December 2012
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.9 | creationdate: 2016-01-21
Kunena version detailed: Kunena 4.0.9 | 2016-01-21 [ London ]
Third-party components: UddeIM 3.7
Plugins: Content - Kunena Discuss 3.1.1
Modules: Kunena Latest 3.1.1
10 years 10 months ago #172402 by 810
you need this on your index.php from your joomla template:
<meta http-equiv="Content-Type" content="text/html;charset=utf-8" />
If you switch back to the default joomla template you will see it will works again.
Time to create page: 0.153 seconds
