Solved We don't see an approve post anymore
11 years 3 months ago #168204 by dianaNashif
We are having trouble approving posts as we moderate all posts in our forum. Used to be that you selected approve and that was it. Now we have to select the user and approve their posts, but it sometimes approves and then not. All we see is a proceed button and it goes to the same page.
Can you give us instructions on how the do this?
www.standupgirl.com
I have search the net and your forum but no information on current version for my issue.
Thank you,
Diana
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 4096M
Joomla default template details : rt_metropolis | author: RocketTheme, LLC | version: 1.8 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: Jomsocial 4.0.8
Plugins: None
Modules: Kunena Latest 3.1.1
11 years 3 months ago #168206 by sozzled
G'day, Diana,
There are a few simple tips to address the age-old problem of knowing where to look when messages are posted in a category that has been marked Review Posts = Yes. Surprisingly, even the people who manage the forum here sometimes forget to use some of these simple techniques.
The first approach (and probably the easiest to implement) is to use the configuration setting Configuration » Security » Security Settings » E-mail Moderators = Unapproved Posts
There are positives and negatives about the effects of this setting. If you have a very busy forum — let's say 50+ messages per day — your forum moderators will each receive emails about every new message posted in your "reviewed categories". If, as you say, all of your forum categories are set up this way, that's the bulk of your work taken up with handling the incoming email traffic. Further, if you have several moderators involved in sifting through the forum activity, the emailing exercise is likely to be counter-productive.
Emailing forum moderators is useful in cases where there is low-level forum activity or when there the forum moderation "team" involves one or two people. In cases where there forum activity is higher (sometimes warranting several people to help with moderating the discussions), some people will attend to the emails (and the approval procedure) before others have a chance to read theirs and the consequence is to break down the moderation team's cohesiveness.
The question, therefore, is "What's an easy way to discover the new messages posted on the forum that need to be approved?" One answer is to create a menu item that lists all messages requiring moderator approval. The problem is to educate and encourage your forum moderators to use this menu item. A couple of years ago I did that here; I created a menu item that forum moderators could use to locate all unapproved messages posted on the forum. You will have to ask the current management team at this site if that menu item is still accessible today.
How to create a menu item for your moderators to locate new posts requiring approval
  1. Go to Menus » Kunena Menu » Add New Item
  2. Select the menu type Kunena Forum » Recent Posts
  3. Enter "Unapproved Posts" as the Menu Title
  4. Select View = Unapproved Posts
  5. Access = Special
Using this menu item, when you see the list of the messages requiring approval you will be able to view each message individually (and approve each of them individually) or you can select all or some of the posts (with the checkbox option) and approve all of them in one hit with the jumpstart/selection tool at the foot of the page.
Yeah, I can relate to your frustration about the lack of adequate documentation on how to proceed with this. I hope that some of what I've written will help you.
11 years 3 months ago - 11 years 3 months ago #168207 by rich
sozzled wrote: Yeah, I can relate to your frustration about the lack of adequate documentation on how to proceed with this.
Before you criticize, you should read the questions. and not only the headline. The problem is that approval does not work.
@dianaNashif
Why must you do this in the user profile?
Last edit: 11 years 3 months ago by rich.
11 years 3 months ago #168208 by dianaNashif
Thank you Sozzled...I do have both you suggestions in place but something is weird now. I have our moderators all set to global. Should I select all categories instead for each?
11 years 3 months ago #168209 by dianaNashif
Because you can not approve otherwise.
There is nothing that says a post was actually approved.
And what does the proceed button do? Click on it and you get the same edit page. Confusing........
11 years 3 months ago - 11 years 3 months ago #168210 by sozzled
dianaNashif wrote: Thank you Sozzled...I do have both you suggestions in place but something is weird now. I have our moderators all set to global. Should I select all categories instead for each?
I'm not sure how to respond after rich suggested that my contribution was [unwarranted] "criticism". As I said, I'm just trying to help. Ideally there should be a readily accessible guide to step people through the approval process but, given the relatively recent decision to exclude public contributions to the Wiki we will have to make do in whatever other ways we can.
I'm surprised that you are unable to approve posts. I'm surprised that you "click on [the user profile page] and you get the same ... page" with no apparent feedback that your action/intervention achieved anything.
I've been using the [menu] method I outlined earlier for some time. I've tested it and it works for me.
Getting back to your approach, I confess that I haven't used the visit-the-poster's-profile-to-approve-pending-messages approach for several years and I'm unfamiliar with the "proceed" button. Therefore, I carried out a test to see how it works on a test site. I could not find a button labelled "proceed".
I could write more but I don't want to dominate this topic. You're right, however; it's a little "confusing", isn't it? :dry:
Last edit: 11 years 3 months ago by sozzled.
