Solved Change CSS Heading Class
10 years 4 months ago #177517 by 810
Replied by 810 on topic Change CSS Heading Class
its the same as K4.
maybe you open the crypsis settings. so try this:
backend - kunena - template manager - click on edit less- click on custom.less
The following user(s) said Thank You: pintobuck
10 years 4 months ago #177525 by pintobuck
Replied by pintobuck on topic Change CSS Heading Class
Yeppers. It's right there like you said. Thank you.
In the meantime, I tried a work-around:
www.kunena.org/forum/general-user-contri...ate-framework#177524 .
Would you suggest that I use the Edit Less method, or is my work-around ok?
10 years 4 months ago #177526 by 810
its the same, so it doesn't matter which option you choose.
