- Thank you received: 4
Kunena 7.0.8 Released
Solved How to change default display order of Sticky Topics?
11 years 1 month ago - 11 years 1 month ago #166676
by nemmar
How to change default display order of Sticky Topics? was created by nemmar
1) I read this post which talks about how to adjust the DB table to make topics more "sticky" and move them up in the display/sort order, as opposed to the default order of newest down to oldest.
www.kunena.org/forum/k-3-0-general-quest...in-a-category#146845
I am wondering if this still applies to the latest version Kunena 4.0.3 and how to use this technique to change the sort/display order of Sticky topics (not regular topics). I want to change the order of how my Sticky topics display in a Kunena category instead of using the default newest first and oldest last ordering. Do you have any advice on this?
2) I noticed that the the latest version Kunena 4.0.3 in the site backend Kunena component dashboard screen it says Codename: Possagno.
I was curious how the Kunena devs chose this name since Possagno is a village in northern Italy.
Thanks.
Thanks.
Last edit: 11 years 1 month ago by nemmar.
11 years 4 weeks ago #166802
Replied by sozzled on topic How to change default display order of Sticky Topics?
As far as I know, the technique you read about in K 3.0 should still work in K 4.0.
11 years 4 weeks ago #166804
by nemmar
Replied by nemmar on topic How to change default display order of Sticky Topics?
Hi Sozzled,
I tested out the Kunena database table edit method in that other forum post but it's not working for me.
But I found a much easier solution that does not require any database table edits...
I just posted a quick reply to each of the Sticky Topics that I wanted to move up in the chronological order of the forum. That way I was able to re-order the Sticky Topics to display sorted based on the topic importance instead of the topic date posted.
When logged in as the forum admin I was able to add the quick replies to locked Sticky Topics.
11 years 4 weeks ago #166806
by 810
Replied by 810 on topic How to change default display order of Sticky Topics?
The sticky loaded the order by the category setting, just like topics.
You can order them by:
- Last post Time
- Topic creation time
- Alphabetic
- Last post Time
- Alphabetic
Time to create page: 0.477 seconds
