Question Very slow posting message in forum
4 days 9 hours ago #234953 by milas
On the forum, when a message is sent, it takes more than ten seconds. If I send a quick reply, it's instant. But if I send a normal reply, it takes a long time.
I tried the basic template. I tried turning off the cache in Joomla.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload:
Joomla default template details : YOOtheme | author: YOOtheme | version: 5.0.30 | creationdate: April 2026
Kunena default template details : NTS KFora | author: Nice Theme Store Team | version: 7.0.1 | creationdate: 2026-04-25
Kunena template params:
Kunena version detailed: Kunena 7.0.4 | 2026-04-19 [ Git Repository ]
Plugins: None
Modules: Kunena Latest 6.2.0
3 days 19 hours ago #234957 by milas
I've tried everything, turned off the basic template, turned off the plugins, nothing helps. Is it possible that my server doesn't allow PHP sendemail, I have to use SMTP email. Although the emails arrive properly.
1 day 14 hours ago #234958 by milas
Does anyone have any ideas?
1 day 13 hours ago #234959 by ruud
sending for a regular message and quick reply is same code: only the entry form is different.
So in short: no idea
You could try enabling Joomla debug, and the debug plugin set to super user account. Then try to login on front-end with super user en try to create a topic.
The debug information in the debug bar might give some idea on what part of the process / which query is taking a longer time.
sharing = caring
1 day 11 hours ago #234960 by milas
I've tried everything, compared the logs, and I haven't found anything that could be the problem. I've disabled additional plugins, modules, and templates, but every time I post a new answer or edit it takes about 10 seconds.
When I reply via quick reply, for example, everything is instant.
I don't know where to look anymore, or what to try.
9 hours 3 minutes ago #234963 by joomod
on my last page I had a similar problem and I found out it was (one) of the used Kunena templates,
not only to switch Kunena to some other template but the problem was gone, when I deleted this template.
give it a try
The following user(s) said Thank You: milas
Time to create page: 0.336 seconds
