Question MySQL upgrade issue - Need help
3 years 1 month ago #229676 by Indrit
Hello, I run my joomla site on Bluehost (shared hosting). Recently i noticed there is a Kunena forum upgrade which I can complete because I get the following message"MySQL 5.7.23-23 is not supported. Minimum required version is MySQL 5.7.30, but it is highly recommended to use MySQL 5.7.30 or later."
I reached out to Bluehost, and they said "Unfortunately it is not possible to update the Mysql database in the shared hosting."
Before I walk away from Kunena, is there a way to solve this even in a shared hosting provider?
Thanks, Indrit
3 years 1 month ago - 3 years 1 month ago #229677 by xillibit
MySQL 5.7.23 is pretty old it has been released in 2018-07-27. Because you are not the only one to ask, I will set the minimum version for MySQL to 5.7.23. It will be present in the next release of Kunena the 6.2.1
Ask to your hoster to update to Mysql 8 or to switch to to Mariadb 10.4 because this are the minimum requirements for Joomla ! 5.0
Last edit: 3 years 1 month ago by xillibit.
3 years 1 month ago #229685 by Indrit
I try to install new updates (Kunena Forum and Kunena Language Pack" and I got the following message
This extension does not provide a checksum for validation of the integrity of the downloaded file.
Extension Update: Custom install routine failure.
Before updating ensure that the update is compatible with your Joomla! installation.
You are strongly advised to make a backup of your site's files and database before you start updating.
info
danger
Error updating package.
3 years 1 month ago - 3 years 2 weeks ago #229693 by xillibit
Like i had said in my previous post you need to wait the version 6.2.1 which allow the instalation from Mysql 5.7.23.  But if you don't want to wait you can use this nightly build which have the fix : update.kunena.org/nightlybuilds/pkg_kune...1-DEV_2023-11-05.zip
For the checksum error message this isn't mandatory to use so don't take attention of it
Last edit: 3 years 2 weeks ago by xillibit.
The following user(s) said Thank You: Marvin McDuck, Indrit
3 years 1 month ago #229721 by Indrit
Very good thank you!
3 years 3 weeks ago #229821 by Marvin McDuck
Details if relevant (I'm in the same boat!) from BlueHost:
Database server
Server type: Percona Server
Server version: 5.7.23-23 - Percona Server (GPL), Release 23, Revision 500fcf5
Protocol version: 10
Web server
cpsrvd 11.110.0.14
Database client version: libmysql - mysqlnd 8.1.16
PHP extension: mysqli Documentation curl Documentation mbstring Documentation
PHP version: 8.1.16
The manuals you find online make it seem as if you can install MariaDB, but so far I haven't been able to. Their hosting is just confusing, layout keeps changing; it greets me with "you have no website, let's make one" as it assumes WordPress -- a few clicks later I have my partial CPanel.
Time to change hosting I guess, I'm fed up.
