Question Can't Change Avatar - Why not?
2 years 11 months ago #229661 by Bobsaap
Your theme is "Can't Change Avatar - Why not?" and now you write "avatar to upload". Is it about "change" or "upload" now?
gindi
If I want to change it, I have to upload it ... :)
2 years 11 months ago #229662 by Leen
Replied by Leen on topic Can't Change Avatar - Why not?
Well, if I see correctly, you use this in kunena
template nts_kinfinite ?
I don't know if there is an option there somewhere to upload avatars
9themestore.com/index.php/our-themes/kun...sive-kunena-template
Perhaps you can also ask your question there in their forum or support
I assume you bought that template
With kind regards
Leen
2 years 11 months ago #229663 by Bobsaap
Yes, it's true - I use template nts_kinfinite.
Okay, I will try to contact their support and resolve problem with them ...
Thanks for HELP!
2 years 11 months ago #229664 by Leen
your welcome
When I search there on their forum I come across a similar problem but no solution
So if they have a solution, we would like to hear it too
so that others might find it useful
With kind regards
Leen
Time to create page: 0.218 seconds
