Question Can't Change Avatar - Why not?
3 years 1 month ago #229621 by Bobsaap
Guys,
I have the problem with changing avatar! :(
I have:
- Default avatar type Image
- enable Allow Avatar Upload
- enable Use Avatars Gallery
- Max. Avatar File Size 500 Kb
- disable Gravatar plugin
And now when I go to frontend and:
- upload my image (it's not seen as uploaded) and click SAVE, nothing happened
- if I choose the avatar from gallery and click SAVE nothing happened
I can't find the way to change the avatars?
Please help!
3 years 1 month ago #229625 by Gindi
The avatar can be changed in the profile.
Click on Profile in the Kunena menu, click on "Edit" in the profile on the right.
In the profile menu bar click on "Avatar".
Here you can upload or remove an avatar.
Gindi
3 years 1 month ago #229656 by Bobsaap
Thank you for reply ...
I know how and where to change avatar ... check my attachement.
But I have a problem ...
When I Choose the avatar to upload I can see the name but It's not uploaded.
And after that I push the SAVE button and nothing happened! :(
I also upload this avatar in the gallery folder and when I choose it from gallery the same story happened - SAVE and nothing.
Thnx and regards!
3 years 1 month ago #229657 by Leen
Replied by Leen on topic Can't Change Avatar - Why not?
Is this difficult, does your image look like the avatar box is from community builder?
Could you please create a recent kunena > tool > Report Configuration Anonymous and post it in your message.
And have you ever tried to test everything with the standard template?
With kind regards
Leen
3 years 1 month ago #229659 by Gindi
Your theme is "Can't Change Avatar - Why not?" and now you write "avatar to upload". Is it about "change" or "upload" now?
gindi
3 years 1 month ago #229660 by Bobsaap
Leen, thanks for idea!
I changed the template of Kunena to Blue Eagle 5 and try to change the Avatar and WORKS.
Looks like the problem is in my template. :(
What could I do in this case?
