Question Dutch language file
And I downloaded the translation at transix for use rename it to nl-NL.com_kunena.views.ini and put it in the folder of my test site (\testkunenazes\language\nl-NL\)
well the old rename there to org_nl-NL.com_kunena.views.ini. then it will look like on my picture
or is this not what you meant?
With kind regards
Leen
I have put a new nightly build under download with changes from transifex from 3 days ago if you want test
For the Kunena menu, i need to look if there is an issue in Kunena which doesn't set language string key in table #__menus
hopefully you will find that for the Kunena menu soon too
I don't know where I could possibly find it
With kind regards
Leen
- HanKortekaas
- Premium Member
- familiewapen
Han
That is why as long as translation for the kunena menu is not going well, I will do it for my Dutch website with kunena
So translate the Titles in the Menus: Items (Kunena Menu) into Dutch only with every upgrade that will be lost
With kind regards
Leen
