Question Kunena ERR ID:1459
3 years 3 months ago #228369 by Gindi
Replied by Gindi on topic Kunena ERR ID:1459
n phpMyAdmin there is an easier way to change the collation of the whole database.
Load the database and click on "Operations" in the menu bar at the top.
Scroll down to "Collation
Scroll down in the pulldown window and select "utf8mb4_general_ci".
Click on "Change all table collations".
Click on "Change all column collations".
Click "OK" on the right
The message "Character set is changed" appears and goes away.
Wait until the message "Character set has been changed" appears.
Greetings Gindi
The following user(s) said Thank You: squeak251
3 years 3 months ago #228372 by squeak251
Replied by squeak251 on topic Kunena ERR ID:1459
Thanks for this. I also had to change the jos_kunena_aliases from the engine MyISAM to InnoDB.
I am wondering if I need to do the same for all the tables.
