Question Kunena / Joomla 4 ?
3 years 9 months ago #226970 by Hifi2you
Replied by Hifi2you on topic Kunena / Joomla 4 ?
When you provide software for a forum/website, the least you can do is make it compatible with updates.
As it stands now, you almost have to be a computer genius to update your forum from running on Joomla 3 to 4. And you can't just leave it on the 3 when support ends.
The fact that private messages don't work should also be fixed.
But yes, I am free to use other software and it will probably end up like that.
But it's not just Blue Eagle that cost a little, the site itself does too, even if it's not much, but I see it as paying for something that doesn't work as intended
3 years 9 months ago #226972 by rich
Replied by rich on topic Kunena / Joomla 4 ?
This is not true. Kunena can be migrated to Joomla 4.x without any problems if the Joomla website has been migrated correctly.
And it may also be that other extensions no longer work with Joomla 4.x. But that is not a Kunena problem, just as it is not our fault that Uddeim has not been developed further since 2017.
3 years 9 months ago #226978 by ruud
Replied by ruud on topic Kunena / Joomla 4 ?
I understand the issue you are having. You just can´t simply upgrade Joomla 3 to Joomla 4, you can't upgrade your current template to a template that is similar and works on J4. Same for some extensions that will need a migration when going from a version that runs on J3 to a version that runs on J4. And once you did.... surprise... there is Joomla 5 and you ccan start all over again :)
Kunena did a great job to help users like you and me upgrade Kunena from version 5 (J3) to version 6 (J4), only thing 'missing' is the blue eagle template, but in my opinion that is a 'good' thing as IMO it was initially build trying to satisfy people coming from Kunena version 2 or 3? It is outdated and should be replaced: Aurelia (that comes out of the box, just like Blue eagle did back in the days) is up to par with latest standards (bootstrap 5).
Running and maintaining a Joomla site takes work, skilled work! The fact that Joomla itself didn't have any major breaking changes made our life 'easier'. if you are not skilled enough to maintain a Joomla site with its extensions (of which Kunena is one), then you are probably better of on a SAAS platform like Wix or the likes. There you have the right to complain if it doesn't work as they are the one maintaining the site for you.
Is Kunena perfect? No it isn't, but it is run / maintained / developed / troubleshooted by volunteers who on a daily basis do their best to make Kunena the best Forum software there is for Joomla.
sharing = caring
The following user(s) said Thank You: rich, anonymous01
3 years 9 months ago - 3 years 9 months ago #226990 by anonymous01
Replied by anonymous01 on topic Kunena / Joomla 4 ?
I'll tell it as a joke.
Joomlart team, which positions its Joomla templates as compatible with kunena - purity III , for example - is now facing some difficulties.
The problem is that Aurelia uses bootstrap 5. I don't know if Joomlart will be able to solve this style conflict.
If there is no solution to the problem, that's too bad...
Last edit: 3 years 9 months ago by anonymous01.
3 years 9 months ago #226996 by ruud
Question is, is that a Kunena or a template issue? Joomla renders it's own components also with Bootstrap 5, even when not using the Joomla build in template. So template developers are already working around conflicts here as well. (in Joomla 5 they are (under discussion) removing that dependency and move everything rendered into the template instead of into the system)
I build my own extensions and I can tell you that the easiest is to use a framework (like bootstrap or UIkit) for your extension, but then you will run into issues with customers who use a non BS / UIkit template. So for my own extensions I created my own css and still I sometimes run into issues / conflicts.
I think that Kunena, being a volunteer based project, did the right thing and adopted BS5 as that is the J4 standard. creating a template like aurelia is a lot of work, creating its own CSS framework to avoid conflict (which is a utopia) is more then double the work.
sharing = caring
3 years 9 months ago - 3 years 9 months ago #227005 by anonymous01
You're probably right. Nevertheless - a very painful transition from J3.10 to J4.*. It reminds me of J1.5 -> J2.5 upgrade (anyone remember jUpgrade?  ).
Which is what this topic proves. Numerous css conflicts, problems with popular components: the death of Uddeim, ridiculous problems with the K2 upgrade. I think the Kunena team would do the right thing if they developed a second (alternative) free template for Kunena 6.
I'd like to take this opportunity to promote K2ForJ4 . A lot of effort has gone into making this fork work properly with Joomla 4. Please test it, if it is interesting for you.
