Question Mail delivery failed: returning message to sender
4 years 2 weeks ago #226553 by gingerweb
Yes no blacklist issues and mail-tester.com reports 10/10 for this domain when sending email so everything is as right as it can be.
it is just when Kunena sends a bunch of emails to category subscribers that the gmail ones get rejected - all the other seem to get through.
This has been going on for weeks i cant find an answer to if anyone else has the same issue maybe it is a Kunena issue?
4 years 2 weeks ago #226560 by rich
Unfortunately I don't know which Kunena version you are using, but in Kunena 6.0.4 some mail problems have been fixed.
4 years 2 weeks ago #226612 by gingerweb
thanks - i am using 5.2.5.
My hosts have eventually decided that it is the mail headers sent out by the forum that are not RFC5322 compliant which Google enforces.
i will have a look at Kunena 6 - is that a simple upgrade from 5 on Joomla 3?
4 years 2 weeks ago #226613 by rich
Upgrading should not be a problem, but I recommend try it with a clone on a test site first.
docs.kunena.org/en/basics/upgrade/upgrade-k6-0
The following user(s) said Thank You: gingerweb
3 years 11 months ago #226840 by gingerweb
Thanks - on the page about K6 it says it is for Joomla 4 is it ok to use on J3 though?
3 years 11 months ago #226849 by rich
It will not work with J3.x
