Question Kunene 6.0.1 - Error while rendering KunenaLayout.
3 years 10 months ago #224009 by wowakan
I had this same thing going on. make sure in your php setting you compile to at last 7.4 and not lower if you are using fastCGI.
3 years 9 months ago #224468 by [email protected]
We are using 7.4 on the site
3 years 9 months ago #224505 by rich
interestingly enough, I did a test and disabled the "Kunena - JomSocial Integration" and the editing categories started working.
  1. Go to the Joomla Global Configuration (System tab) and enable Debug mode.
  2. On the Server tab, select Error Report = Maximum.
  3. Also enable debug mode in the Kunena configuration (General tab).
  4. Enable the plugin JomSocial - Integratiom again
Perhaps there will then be a meaningful error message.
Time to create page: 0.462 seconds
