Question Kunene 6.0.1 - Error while rendering KunenaLayout.
4 years 4 months ago #223915 by [email protected]
I have this error message suddenly popping up when I try to edit a category. Straight after installation everything works fine, but after few days, this starts popping up
Error while rendering "update" as the query type is already set to "select". You should either call the `clear()` method to reset the type or create a new query object.
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 1024M | Max file upload:
Joomla default template details : shaper_helixultimate | author: | version: 2.0.10 | creationdate: Feb 2018
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.1.1 | creationdate: 2022-07-09
Kunena template params:
Kunena version detailed: Kunena 6.0.1.1 | 2022-07-09 [ Git Repository ]
Third-party components: Jomsocial 4.8.2
Plugins: None
4 years 4 months ago #223916 by [email protected]
The Kunena Template states: Aurelia template using Bootstrap 5 and SCSS
In the Template details however there is: Load Bootstrap css - No
4 years 4 months ago #223921 by Leen
does this message only occur when you want to modify or edit a kunena category?
or even if you try to edit a joomla category or article ?
With kind regards
Leen
4 years 4 months ago #223922 by [email protected]
I am not really using Joomla Categories/Articles as I am using the HelixUltimate and SP Page
So for me it is only when I try to add/edit category in Kunena Front/Backend. I was even able to post in a category and moderate it (delete).
Cheers,
Kimmo
4 years 4 months ago - 4 years 4 months ago #223941 by Leen
Don't know if you've already done this
If you are using the shaper_helixultimate Joomlatemplate, you need to disable "Load Bootstrap css" in Aurelia (Advanced tab)
. but you can only edit that of categories in the administrator area, right?
is this forum new or an Upgrade from a previous version kunena ?
 can't come from jomsocial ?
With kind regards
Leen
Last edit: 4 years 4 months ago by Leen.
4 years 4 months ago - 4 years 4 months ago #223943 by [email protected]
as mentioned above, the setting for Load Bootstrap in Aurelia is set to "NO".
I can not edit the categories in Admin-area
it is a fresh install of Kunena so no upgrade there..
interestingly enough, I did a test and disabled the "Kunena - JomSocial Integration" and the editing categories started working.
Since this is a Kunena Plugin, would you guys look into it please?
Last edit: 4 years 4 months ago by [email protected].
Time to create page: 0.166 seconds
