Question Modules assigned to forum page dont show
Can you tell me which types can be fixed automatically if I provide you with the list?
Returning to the original and important issue
i asked Rockettheme and they replied that the Supra version I am using on Joomla 3 is bootstrap 2.3.2I think the Rocketheme Supra is written for Bootstrap 5. If so, it will not work, because we don't have a Bootstrap 5 capable template for Kunena
This leaves these issues still unresolved
2. The modules I assigned to the menu item do not show
3. The layout is not formatted the search button is covered or overlapped in z-index or padding issue
4. In the tools section using diagnostics I see about 100 issues reported in dev site and almost the same in live site
Thank you
However, this can also lead to the next message.
Example:
If you remove an orphaned message, the next message "messageBodyMissingMessage" may appear. This must then be fixed as well.
I don't know your errors and I don't know all the errors that are possible.
First recount the statistics and see if there are fewer messages.
In my tests I never had problems with this option, but something can always happen.
Please check the module positions again, they are not the same for all templates. And also in the module itself, whether this is assigned to all menu items.The modules I assigned to the menu item do not show
In this case, Crypsis should work. But you can try in the Crypsis setting "Load bootstrap css = Yes".The layout is not formatted the search button is covered or overlapped in z-index or padding issue
Crypsis = bootstrap 2
Crypsisb3 = bootstrap 3
Crypsisb4 = bootstrap 4
I have found the issue.
It is because you must select all the sub menu and the parent menu item in the module assignments tab
Then unpublish the module instance in the outline if you dont want it to show two or pick either module assignment or module instance in the outline
Hopefully this will help others in the future
Now the remaining questions are for fixing the errors in the list below and the search bar overlapping the button behind it?
for search field
#kunena .layout .search-query {
width: auto;
margin-top: 30px;
Of for button
.form-search .input-append .btn {
border-radius: 3px;
margin: 10px;
min-width: 50px;
Change the tooltip to say click the button this needs work or remove the button completely with the following CSS
border-radius: 3px;
margin: 10px;
min-width: 50px;
display: none;
This is the list
messageMissingMessageBody TEST FAILED 1 issues DELETE BROKEN ITEMS
topicMissingMessages TEST FAILED 2 issues DELETE BROKEN ITEMS
messageOrphaned TEST FAILED 4 issues DELETE BROKEN ITEMS
attachmentOrphaned TEST FAILED 85 issues DELETE BROKEN ITEMS
userReadWrongCategory TEST FAILED 1 issues FIX ISSUES
userTopicWrongCategory TEST FAILED 1 issues FIX ISSUES
I verified with Rockettheme the module is assigned properly
I set the Crypsis setting "Load bootstrap css = Yes" as requested the result was minor spacing but overlap and still no modules
Thank you
Or a user do not use the cancel button if he not send after image upload his message. All this attachments get the mesid 0 in the table #__kunena_attachments.
You can see in the frontend in the message "You do not have permissions to access this page." instead of this image.
The rest are just some messages. I do not see any problem.
As for Crypsis, does it work with the Joomla template Protostar?
No I tried another template and the button is hidden under the search field
It doesnt make sense anyway because the mouseover modal info popup doest explain you need to click the button and the button itself doesnt have any words on it so nobody would no what to do in most cases.
I would rather takeaway the button and improve the wording in the popup modal.
Do you anyway to do any of those options?
