Question Modules assigned to forum page dont show
Below is the summation of the versions we have changed to
- Version:5.2.6 on dev site Template : Crypsis /5.1.7 on live site Template : Canvas/ 5.2.8 is latest version
The Kunena template we used on the live site is no longer available
We are using Rocketheme template called Supra
After creating the menu item in our main menu for Kunena forum with an alias menu type, I chose the rocketheme template in the menu item field
I saved it
Then there are a few issues
Typically I see it filled for example like
2. The modules I assigned to the menu item do not show
3. The layout is not formatted the search button is covered or overlapped in z-index or padding issue
4. In the tools section using diagnostics I see about 100 issues reported in dev site and almost the same in live site
4A. Can I see those issues before hitting the fix link?
4B. Should I fix all of them by hitting the fix links?
Thank you
- Thank you received: 2545
On the dev side, why don't you have the same Crypsis version as the Kunena version?Version:5.2.6 on dev site Template : Crypsis /5.1.7
If you have other software installed on the dev side and only import the database, it will cause errors. Better would be to clone the live site, and then update everything.I am using a dev site and have imported the database tables from our live site.
I think the Rocketheme Supra is written for Bootstrap 5. If so, it will not work, because we don't have a Bootstrap 5 capable template for Kunena 5.2.x. That is only available for Joomla 4 and Kunena 6.0.We are using Rocketheme template called Supra
The live site is malfunctioning old and huge and I can not clone it nor do I want to.
The Kunena template we used on the live site is no longer available in the new Kunena versionOn the dev side, why don't you have the same Crypsis version as the Kunena version?
Ok I will verify with Rockettheme, however Kunena is working fine except:I think the Rocketheme Supra is written for Bootstrap 5. If so, it will not work, because we don't have a Bootstrap 5 capable template for Kunena
If I use a menu alias that is standard practice for Kunena it works and looks fine however It does not show assigned modules
If I dont use menu alias then the inner nav bar tabs do not show and the formatting is wrong , I have written CSS to override it and it works but this is not good practice because every Kunena update will overwrite it.
That is why I asked you above
If I click those links on the dev site or find out what the fixes are I may fix the issue, could you reply to those questions please?4. In the tools section using diagnostics I see about 100 issues reported in dev site and almost the same in live site
Thank you
If the live page is too large, then the imported database is also too large. This then contains everything that you actually no longer want. Or have you only imported the Kunena tables?The live site is malfunctioning old and huge and I can not clone it nor do I want to.
This has nothing to do with other templates. Crypsis is the system template of the Kunena 5.x series, and no matter which Kunena version is installed, the same Crypsis version must always be present. So something is wrong.The Kunena template we used on the live site is no longer available in the new Kunena version
It displays orphaned database entries. This function should be used with caution because it deletes database entries.4. In the tools section using diagnostics I see about 100 issues reported in dev site and almost the same in live site
docs.kunena.org/en/manual/backend/tools/diagnostics
Correct I only imported very specific tables including KunenaIf the live page is too large, then the imported database is also too large. This then contains everything that you actually no longer want. Or have you only imported the Kunena tables?
Template is called Canvas/ version is 5.1.7 on live site .This has nothing to do with other templates. Crypsis is the system template of the Kunena 5.x series, and no matter which Kunena version is installed,
I do not see a template called Canvas on the dev site
The Crypsis template is present and available on both the dev and the live sitethe same Crypsis version must always be present. So something is wrong.
The template i am using on the dev site is Crypsis
On the live site the template I am using is Canvas and yes the Crypsis template is present and available bit I am not using it I am using Canvas.
The issue is I dont have Canvas template available on the dev site because the Kunena version is a newer version and the canvas template does not come with it installed
Yes I will back up first however my question was can I see the errors before clicking the links to fix them?It displays orphaned database entries. This function should be used with caution because it deletes database entries.
Thank you
In principle, it is possible to check this in advance, but it is not always easy. You have to see the context.Yes I will back up first however my question was can I see the errors before clicking the links to fix them?
Example: You have orphaned attachments in the list. In the #__kunena_attachments table you will find some entries with mesid 0, i.e. these attachments are not associated with any message. If you click Repair, these entries will be removed.
Or category missing alias, then you will find a missing entry in #__kunena_aliases. This must be repaired manually. Not all can be repaired automatically with the FIX button.
