Question eBay widget not working
5 years 2 weeks ago - 5 years 2 weeks ago #220049 by larbut
The ebay widget does not seem to work on my site and not on this site when I tested in this topic:
Nothing shows up using the widget, and pasting the URL to the eBay add also shows nothing.
I have "Auto Embed eBay Items" to "yes" and the proper values on the other three eBay configuration settings.
Kunena 5.2.6 and Blue Eagle 5 ver 1.66
I get the same problem using the ebay widget in this forum:
www.kunena.org/forum/general-questions-a...os/163318-e-bay-tags
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 16M
Joomla default template details : rt_nuance | author: RocketTheme, LLC | version: 1.7 | creationdate: September 27, 2017
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.6 | creationdate: 2021-07-25
Kunena template params:
Kunena version detailed: Kunena 5.2.6 | 2021-07-25 [ Melia ]
Third-party components: CommunityBuilder 2.6.4 | UddeIM 4.0
Third-party SEF components: sh404sef 4.10.0.3607
Plugins: Search - Kunena Search 5.2.2
Modules: Kunena Latest 5.2.2 | Kunena Search 5.2.2
Last edit: 5 years 2 weeks ago by larbut.
5 years 2 weeks ago #220054 by rich
Replied by rich on topic eBay widget not working
Maybe you need the right eBay Widget Language Code. In your configuration is chosen en-US
4 years 11 months ago - 4 years 11 months ago #220493 by larbut
Replied by larbut on topic eBay widget not working
No eBay APP ID and/or Cert ID defined in Kunena configuration
No, I have it set to en.US, as it always has been.
Testing ebay widget on this forum:
Edit: No, does not work on this site either.
Last edit: 4 years 11 months ago by larbut.
4 years 11 months ago #220525 by xillibit
Replied by xillibit on topic eBay widget not working
I will investigate into this issue to see what's happens exactly
The following user(s) said Thank You: larbut
4 years 11 months ago #220640 by larbut
Any news on this issue?
4 years 11 months ago #220646 by xillibit
I have looked it seems that eBay has how it works to authenticate to use their API so i need to change the code in Kunena to make it working
Time to create page: 0.169 seconds
