Question Change Domain Components Templates Timeout
5 years 7 months ago - 5 years 7 months ago #217107 by toomanylogins
Yes thanks checked and deleted caches. Gets even more weird. I just did tools - uninstall. Checked database and the tables had been deleted. Then reinstall the component 5.2.4. Same problem.
I normally run my sites behind reverse proxy however editing the hosts file and accessing the server directly the error I am getting is "file not found"
Last edit: 5 years 7 months ago by toomanylogins.
5 years 7 months ago #217111 by toomanylogins
Ive got to bottom of problem. By default our firewall blocks outgoing traffic. Kunena on the template link is trying to contact the Kunena server to get a list of paid templates. This causes a timeout and our reverse proxy gives an error. I would consider this a bug.
Paul
5 years 7 months ago #217127 by xillibit
I need to look if i can add a check for timeout when it tries to load the external file, to avoid this kind of issue
