Question Change Domain Components Templates Timeout
5 years 7 months ago - 5 years 7 months ago #217087 by toomanylogins
I have moved site to a new domain name and I'm having a problem with the administration backend components templates. When I click on the template's link the system times out. Everything else is working okay and I have checked the Joomla! configuration paths etc. I have checked the database sql references to the old domain etc. Is there anywhere else where Kunena is saving the configuration path to the template ?
Updated to latest 5.2.4 without a problem.
Paul
Last edit: 5 years 7 months ago by toomanylogins.
5 years 7 months ago #217089 by xillibit
Try do enable debug mode and developpement mode in Joomla! configuration panel to see if there are some errors displayed
5 years 7 months ago #217090 by toomanylogins
Thanks for suggestion. As the page just hangs ie its a timeout I dont get error in debug console.
Cant work it out.
5 years 7 months ago #217091 by toomanylogins
I have this error in apache logs see snippet. Anyone shed any light on this ?
P 9. KunenaAdminControllerTemplates->executeTask($task = 'display') [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fkunena&subscriptionId=15&file=controller.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/kunena/controller.php[/url]:215PHP message: PHP 10. KunenaAdminControllerTemplates->display($cachable = *uninitialized*, $urlparams = *uninitialized*) [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fkunena&subscriptionId=15&file=controller.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/kunena/controller.php[/url]:324PHP message: PHP 11. KunenaAdminViewTemplates->displayAll() [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fkunena&subscriptionId=15&file=controller.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/kunena/controller.php[/url]:441PHP message: PHP 12. KunenaAdminViewTemplates->displayLayout($layout = *uninitialized*, $tpl = *uninitialized*) [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fkunena&subscriptionId=15&file=view.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/kunena/view.php[/url]:137PHP message: PHP 13. KunenaAdminViewTemplates->displayDefault(NULL) [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fkunena&subscriptionId=15&file=view.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/kunena/view.php[/url]:209PHP message: PHP 14. KunenaAdminViewTemplates->get($property = 'Templatesxml', $default = *uninitialized*) [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Fadministrator%2Fcomponents%2Fcom_kunena%2Fviews%2Ftemplates&subscriptionId=15&file=view.html.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/administrator/components/com_kunena/views/templates/view.html.php[/url]:32PHP message: PHP 15. KunenaAdminModelTemplates->getTemplatesxml() [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Flibraries%2Fsrc%2FMVC%2FView&subscriptionId=15&file=HtmlView.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/libraries/src/MVC/View/HtmlView.php[/url]:425PHP message: PHP 16. KunenaAdminModelTemplates->loadTemplatesXml() [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Fadministrator%2Fcomponents%2Fcom_kunena%2Fmodels&subscriptionId=15&file=templates.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/administrator/components/com_kunena/models/templates.php[/url]:407PHP message: PHP 17. Joomla\\CMS\\Http\\Http->get($url = 'https://update.kunena.org/templates.xml', $headers = *uninitialized*, $timeout = *uninitialized*) [url=https://10.10.10.19:8443/smb/file-manager/code-editor?currentDir=%2Fhttpdocs%2Fadministrator%2Fcomponents%2Fcom_kunena%2Fmodels&subscriptionId=15&file=templates.php&redirect=%2Fsmb%2Flog-file%2Fbrowser%2Fid%2F15]/var/www/vhosts/youdocms.com/httpdocs/administrator/components/com_kunena/models/templates.php[/url]:
5 years 7 months ago #217092 by toomanylogins
Here is config.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : vg_cacoon | author: Valentín García | version: 1.1.0 | creationdate: November 14 2018
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.4 | creationdate: 2021-04-04
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Plugins: None
5 years 7 months ago #217094 by rich
Have you emptied the cache afterwards? Maybe it loads the wrong paths from the cache.
Time to create page: 0.159 seconds
