Question How to change an attachment folder?
6 years 10 months ago #211968 by Igor_77
Hi!
I want to know how can I change the attachment folder?
I have read this stuff - www.kunena.org/forum/159-K-17-Common-Que...stom-image-directory
The reason I would like to do that - is to pay less for the images saving, I can mount one more disc to my server that cost lower price and to use it for attachments.
Is it possible to realize that?
6 years 6 months ago - 6 years 6 months ago #213021 by gojeto
Hello, still no answers to that ? Have you even found a solution to it or not yet ?
________________________________________________________
SHAREit MX Player
Last edit: 6 years 6 months ago by gojeto.
6 years 6 months ago - 6 years 6 months ago #213026 by 9themestore
@Igor_77, @gojeto,
The Kunena component does not support change the attachment folder path in the back-end. So you can change the folder path in the core files of Kunena component. I tested and it worked fine. Follow some bellow steps to change the attachment folder path.
- Step 1: Backup your site.
- Step 2: Open three files:
[root]/libraries\kunena\attachment\attachment.php [root]/libraries\kunena\bbcode\bbcode.php [root]/administrator\components\com_kunena\install\model.php
- Step 3: Replace the "/media/kunena/attachments/" path to your path. (example: /media/kunena/attachments2/).
- Step 4: Reload your site and try to add a file to your post.
Please do above steps on dev site before apply to the main site.
Best regards,
Last edit: 6 years 6 months ago by 9themestore.
