Question Emojis crashing web page
8 years 3 months ago #202405 by mario87
Replied by mario87 on topic Emojis crashing web page
same problem with jsn theme template.
With Crypsis it works great!
8 years 3 months ago - 8 years 3 months ago #202420 by Nikiniko
Replied by Nikiniko on topic Emojis crashing web page
and here same error
bootstraps are on
Crypsis Kunena Team 5.1.1 updated emoticns dont work
Crypsisb3 Kunena Team 5.1.1 2018-06-10 updated emoticns dont work
Kinstance Roundtheme 1.2.0 2017-11-01 NOT updated emoticns WORKS
NTS KSamurai Nice Theme Store 5.2.1 2018-06-17 updated emoticns dont work
Last edit: 8 years 3 months ago by Nikiniko.
8 years 3 months ago - 8 years 3 months ago #202423 by Bigbunny
Replied by Bigbunny on topic Emojis crashing web page
Just observations as an onlooker. Some templates and frameworks just behave badly with some other extensions. That does not mean that there is not a problem with Kunena but it could be other reasons. I had to ditch JSN when I was testing it as it caused issues with other templates and some extensions. Some template producers have templates specifically for Kunena that I assume they have checked works with it. You sometimes come across a clash. I assume that you have discussed this with Helix and not just Kunena. Just not using a template or extension is not always sufficient. Completely disabling or removal in some instances is required so if you have something that you no longer use but is still installed, especially if getting on a bit, it's wortt looking at. You will possibly need to test to see if something else is affecting what you are seeing and that will be a matter of test and trial.
One other thing is that you state that you don't have an SSL certificate. I would advise that you do so quickly and set up your site to only use https://. (You can usually redirect http to only use HTTPS but don't do until you have installed a certificate unless you want nobody to access it.) At present browsers will come up with an issue if you point to https without a certificate and users can then try using http. Shortly browsers will stop responding to non https sites. Personally I don't like using any site that is not secured with an SSL/TLS certificate and uses it. You have people logging into your site and at present that is unencrypted so anybody with the necessary skills, or computers set up to do this, can monitor all the transactions including login details. Have a look at the free LetsEncrypt certificate and see if it will do what you want. I have used these on club and test sites and depending on your host they may already include for it.
Last edit: 8 years 3 months ago by Bigbunny. Reason: Added content
Time to create page: 0.235 seconds
