Question Emojis crashing web page
8 years 6 months ago #199953 by [email protected]
Hi i have a problem when you click an emoji to insert, it crashes the webpage. I have turned error reporting to the maximum and it is not throwing up any errors.
You can try and post here as a guest to see what happens.
Also the recaptcha is above the post and not below it like on here
Any help would be appreciated
www.opticalexpressruinedmylife.co.uk/opt...discuss/topic/create
8 years 6 months ago #199957 by 810
Replied by 810 on topic Emojis crashing web page
1) update your ssl license, or disable it.
2) at the template options, set "Load bootstrap" to yes, and save
8 years 6 months ago - 8 years 6 months ago #200099 by [email protected]
810 wrote: 1) update your ssl license, or disable it.
Thanks for the reply. we do not have an ssl license activated on the site. I have turned load bootstrap to yes in the Kunena templates settings and I am still not further forward.
i have also reinstalled the entire forum this morning and nothing changes
any other suggestions please?
Last edit: 8 years 6 months ago by [email protected].
8 years 5 months ago - 8 years 5 months ago #200118 by [email protected]
OK so an update on this. I changed the template to Protostar and it works fine. I turn it back to Helix Ultimate and it does not work fine. I tried to install Helix 3 and test it with that. It does not work fine.
I am using Bluestork template which is just about usable but both the Crypsis templates are absolutely unusable.
So there seems to be a major compatibility problem with Joomshaper.
Is there a fix for this?
Last edit: 8 years 5 months ago by [email protected].
8 years 5 months ago #200126 by [email protected]
Ok an update from my earlier post (and to help you guys out)
I have installed a fresh version of Joomla on a totally separate hosting environment. installed Helix Ultimate and Kunena.
Same problem.
You can see it here
creativetemplates.online/test
8 years 5 months ago #200243 by [email protected]
Any chance on helping me out here please?
