Question Error message after updating to 5.1
5 years 11 months ago #1 by velieb
After I updated to 5.1, I got this error message, "Rendering Error in layout Widget/Menu: Unsupported operand types. Please enable debug mode for more information."
5 years 11 months ago #2 by 810
Please try to enable kunena debug on the kunena configuration.
Then the real error will be showed. Or go to backend -kunena- logs there you will see the error also
5 years 11 months ago - 5 years 11 months ago #3 by velieb
Thanks, I followed the instruction, then the detailed error has displayed as follow:
Rendering Error in layout Widget/Menu: Unsupported operand types in /home/my-site/libraries/kunena/layout/base.php on line 166
Layout was rendered in /home/my-site/libraries/kunena/layout/layout.php on line 79
Last edit: 5 years 11 months ago by velieb. Reason: Wrong attachments removed
5 years 11 months ago #4 by 810
could you add the kunena report.
5 years 11 months ago #5 by rich
Have you set in the Joomla configuration "Add Suffix to URL = Yes" ? Please set it to No and test if the error is gone.
5 years 11 months ago - 5 years 11 months ago #6 by velieb
Here you go...
Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 160 seconds | Max execution memory: 1024M | Max file upload: 24M
Joomla default template details : rt_myriad | author: RocketTheme, LLC | version: 1.3 | creationdate: October 9, 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.1-DEV | creationdate: 2018-05-15
Kunena template params:
Kunena version detailed: Kunena 5.1.1-DEV | 2018-05-15 [ Internal ]
Third-party components: CommunityBuilder 2.1.4 | UddeIM 3.9
Third-party SEF components: sh404sef 4.13.2.3783
Plugins: None
Modules: Kunena Search 5.1.0
Last edit: 5 years 11 months ago by velieb. Reason: config after dev. version installed
5 years 11 months ago #7 by velieb
Just checked, the setting was 'No'
5 years 11 months ago #8 by 810
we think we have fixed it, could you try the nightly build. its on the bottom of the download page
5 years 11 months ago - 5 years 11 months ago #9 by velieb
I still get the same message after installing nightly build. I updated the report above with nightly build.
5 years 11 months ago #10 by 810
mhh, so with K5.0 there is no error?
Time to create page: 0.549 seconds
