Question Registered users can't edit own posts any longer
- KennethHansen
8 years 3 months ago #197966
by KennethHansen
Registered users can't edit own posts any longer was created by KennethHansen
Hi community and Kunena staff.
We're facing a problem with our Kunena-board, and it all came out of the blue.
Our registered users suddenly can't any longer edit their own post or topics. People says that the "Edit" button doesn't even appear.
Strange thing is, I didn't edit any settings or configurations prior to the problem.
Checking Kunena > Configuration > Frontend > "Let users edit the subject", it is indeed still ticked as "Yes".
Also went to the individual categories, to see if I by mistake had changed the rules, but all seems correct.
To cross-check, I also tried to register a new user myself, and logged in as this new user, I'm perfectly fine allowed to edit both my own posts and topics, which leads me to think the problem only exists for registered users prior to some specific date of whatever event occured, that caused the problem.
Any ideas?
Any file or configuration I can check directly too see, what could be going on?
Any ideas?
- WolfgangOWL
- Senior Member
8 years 3 months ago #197970
by WolfgangOWL
Replied by WolfgangOWL on topic Registered users can't edit own posts any longer
The following user(s) said Thank You: KennethHansen
- KennethHansen
8 years 3 months ago #197971
by KennethHansen
Replied by KennethHansen on topic Registered users can't edit own posts any longer
Oh, a bug with the latest Kunena-update?
Thanks, will try it right away!
8 years 3 months ago #197975
by rich
Replied by rich on topic Registered users can't edit own posts any longer
@Wolfgang
With K 5.1 it should work again. It's now added additional to the others options.
github.com/Kunena/Kunena-Forum/pull/5715
github.com/Kunena/Kunena-Forum/pull/5720
Time to create page: 0.291 seconds
