Question Images Not Displaying Correctly ver 5.013
8 years 9 months ago #197494 by rich
It's not possible to analyse your page with the browser tool, when all will loaded from compressed files. Please disable the optimization, then you must also empty the cache.
8 years 9 months ago - 8 years 9 months ago #197495 by benign01
I have disabled the JCH tool and refreshed the cache several times. Please could you take a look now try this page www.birminghamgoldcompany.co.uk/forum/go...e-in-2018-onwards#13
I see no avatars yet when you click on where the avatar should be you are taken to the profile and the avatar then shows.?!
Last edit: 8 years 9 months ago by benign01.
8 years 9 months ago #197496 by rich
You get the errors from the PageSpeed module, which you've installed on your server. Maybe the module is broken or not correctly configured. Disable it in the php.ini file.
8 years 9 months ago #197498 by benign01
Thanks I turned it off via .htaccess. Not sure how to do it via php.ini. Now it all works again
Thanks. I thought it was an instability re Kunena, especially as I have not been on my site for 2 weeks and it worked previously BUT it must have been some error at the server level i will check. Thanks for your help
Lionel
Time to create page: 0.286 seconds
