Question Images Not Displaying Correctly ver 5.013
8 years 9 months ago - 8 years 9 months ago #197484 by benign01
My images have disappeared from my posts as has my avatar (I am super user....other avatars still show)
The images do not show, instead there is code ie Presentation1_2017-12-20.png where the image should appear. (see attachment) What is causing this
Have upgraded to latest version ie 5.0.13
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : protostarplus | author: Maarten Blokdijk | version: 1.0 | creationdate: 04/13/2016
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.13 | creationdate: 2017-12-31
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Third-party components: AltaUserPoints 1.1.11
Plugins: Content - Kunena Discuss 5.0.3
Modules: Kunena Latest 5.0.3 | Kunena Login 5.0.3 | Kunena Search 5.0.3
Last edit: 8 years 9 months ago by benign01.
8 years 9 months ago #197485 by 810
for me, the images are showed correctly, please try cleaning your browser cache.
8 years 9 months ago #197487 by rich
I think your problems comes from the optimization tool. The address to the broken images are wrong:
The requested URL /media/kunena/avatars/resized/size144/users/xavatar418.png.pagespeed.ic.flX2gSeSHk.webp was not found on this server.
8 years 9 months ago - 8 years 9 months ago #197491 by benign01
Ok Thanks for the input. So what do i have to do to fix the issue..Even with jch optimize switched off it still does not show images AND this all happened out of the blue. i had not worked on the site till before XMAS and it was fine then
8 years 9 months ago #197492 by benign01
I have noticed that if I click on the image html (as per the example i attached) It opens a window box and shows the image. I am confused see here www.birminghamgoldcompany.co.uk/forum/pa...ticipate-earn-points
8 years 9 months ago #197493 by benign01
I seem to have fixed the images but the avatars are not showing, that is everyones, Any ideas?
Time to create page: 0.264 seconds
