- Thank you received: 2534
Question COM_KUNENA_WARNING_MENU and all other _MENUS appeared
Maybe this line is not translated in your language, but it has nothing do to with broken menu items.I just installed language packs if you remember.
Maybe it helps if you click the Rebuild button. Example: Menus -> Main Menu -> mark menu items -> Rebuild ( but create a database backup previously).How can I check my menus? Please give me details.
So tell me how can I translate this greek file. What file should I edit (exact path) and in which line?
Also I can help you with greek translation as I have worked in 3 joomla components in the past. JReviews, JomSocial and JFB Connect.
I've checked it, this line is correctly translated. But is has nothing do to, that the message is displayed.Maybe this line is not translated in your language
Exactly should that be displayed "Το προκαθορισμένο στοιχείο μενού στην Σελίδα Εισόδου δεν δείχνει στο Kunena."
So check the menu Kunena item "Home Page" ( see also here ).
If you want help, please create a account on Transifex , then click on Request for Greek language.Also I can help you with greek translation as I have worked in 3 joomla components in the past. JReviews, JomSocial and JFB Connect.
Create a backup from your database.Also what should I backup before doing this?
Example: Go to main menu and mark the menu items. On top you find the Rebuild button.Ok so Iam a bit confused. Shall I click the "rebuild" button? Where is that?
I found the menu in Main Menu but I can't find the Rebuild button.
Thanks.
